SignUp Now!??? Not sure what you mean Brent.edit the first line in post 18. or del it please![]()
You owe me a 30 pack Brent.reed and the cat
Edited quite a few Brent so I hope I get at least a keg of whiskey now. (101 proof)thanks now fixs the quotes. i got something coming for you. its better then a 30 pack
I really think the best way to reduce the intake temps is to reduce the total amount of boost needed. I think a hot air could really stand to have much much higher compression to help make the power . Then one good use less boost but still move x amount of air to make x amount of HP.
The added compression will also add low end torque to help get past any lag .
Charlie I still disagree that a gutted intake causes lag .....
Boost231 said:^ what kind of turbo would that be?
a year or so back, i posted a question about building a 4.1 for my 84 T Type with about 10:1 compression that used the later heads like the ones used on the TTA with a reverse dome piston that mirrors the chamber shape to be run on E85.. the general consensus was that i was crazy for wanting to try such a crazy thing. a few people didn't know what a reverse dome piston was, but there was a discussion about them and what quench is and that kind of thing.I really think the best way to reduce the intake temps is to reduce the total amount of boost needed. I think a hot air could really stand to have much much higher compression to help make the power . Then one could use less boost. but still move x amount of air to make x amount of HP.
