the window is exposed to the sun, straight ammonia and cover with a black plastic ( garbage can liner ). Be sure to ventilate the area well. Let sit for 30 minutes and pull off tint. If it does not pull off easily, rewet and try 30 minutes later. It should pull off easily and leave very little residue. The sun must be on the window to expediate the process.
White T Type 989, you are a LUCKY man. She is HOT!!!
