How to stop kickdown on chassis dyno?
TheFearless427
Hi Everyone,
I'm looking to get my car on the dyno, but at low RPM and full throttle the 200-4r will downshift into 2nd from third. Does anyone know a way to lock this out so that I can got WOT and stay in 3rd?
Change the gov. for the dyno test, or start from a higher rpm where it won't downshift.
Get the driveshaft speed up high enough and it won't downshift.
What Bison said ^^^
Get the speed up before you lay into it. If it kicks down, abort and try again. Bring the speed up a little higher until you find the sweet spot. Usually 50-55 mph is a good point to hit it.
