BOJANGLES
Its alright.
- Dec 16, 2015
i purchased a set of 15x10 GN repro. wheels, gbody parts states its made to take a 275/60/15. i would like that size but can i go 315 wide? anyone have any pictures of a 315/60/15 on their GN?
SignUp Now!What did you do to fit that?315/50/15 MT DR's.
i run the 315 pro radial,any 315 will not fit without work being done to the car.i would like that size but can i go 315 wide?
great thought but in stock form its not going to happen.I just have s friend of mine putting a big in my ear about s bigger tire..
thats a nice tire for these cars without alot of drama making it fit.I run the 295/55 on that wheel.
Pics of the 315 pro?i run the 315 pro radial,any 315 will not fit without work being done to the car.
right now its off the car.i probably have some older ones, would rather due that in a pm as its really a n/t car.car also has a 9 inch in it.Pics of the 315 pro?
mtWho makes a pro radial?
i got that 295/65/15 i both the hoosier and mt on the stock rear in pretty good before going to the 9 inch.the hoosier is easier because its not as tall but the mt is a real 30 and pretty much fills up the well and near the frame,i had custom spacers made and ran an 8 inch rim with the right backspace to make it work,also had airbags but could take the air out if i choose.i trimmed and cut the fender also,but no notch and used the stock tubs.on my friends car we hammered the frame to get a full tuck in on the 295/60/15 but he was on a 9/10 inch rim.he ended up notching the frame and dropped back down to a 28.on my car i went to the bigger 315 pro but with a 9 inch and custom ends and the 315 pro inmo still really needs a minitub to really have a slammed stance with a full tuck in the rear but i went no faster dropping my rear down that low so i thinks its a waste for all work but some just like the look. ive run 26/28 inch tall tires on the front also but there will still be a rake.295/65 with the car low enough to tuck tire. The 30" height really makes it tough, and the 295/65 is tight in the stock massaged wheel tub.
