TurboTnZ06
Go on red!
- May 7, 2002
I just got this all together and backed out of the garage. It seems to leak (heavily) between where the master bolts to the booster. Sure I did try to build some boost by power braking it in the driveway. It's brake fluid. The two lines are dry that go to the front and rear brakes. Is it possible a reman master already has its seals toasted? Is it possible I pushed the master too far while power braking?
