I know how to fix cam thrust surface on block
Boost231
What's An Intercooler
Staff member
take a look at my web site http://community.webshots.com/user/boost231.
these 4 blocks are on the way to the machine shop to have a c&c program made to cut the cam thrust surface and install a roller bearing to the cam surface. this is a perment fix and its alot better then the stock block. with this bearing you will never have to worry about having the surface wearing again.
brent
looking for more info on the roller cam bearings. Where can I find it? This seems like a pretty smart thing to do, like you said, no more wear to the surfaces. Where can the proper bearings for our blocks be purchased?
ok
i can get the proper bearing for you if u need it. do u have access to a c and c program? well with this bearing the block has to be machined with the c and c to make it when you put the bearing in its flat to the rest of the block. let me know if u want me to get you a bearing.
brent
