I meed an on center measurement of a B&M trans lever
BlackBandit
God loves Buicks!
I have a B&M prostick shifter but I don't have the lever that comes with it to replace the factory lever on the transmission that the cable attaches to. I was wondering if anyone could give me the on center measurement from the trans hole to the hole where the cable attaches (for the prostick) so that I can build my own. Thanks. james
Bracket Dimentions
What type Trans are you using? If your using a GM Trans the length from the (center of the Shaft to center of Cable hole is 1.9" ) and the Cable hole is 1" forward of the Shaft centerline. The Rectangle Shaft hole is .508 X .334 and is turned to the left about 20 Degrees. Tried to draw a Pic but it turned out screwed.
I have a 200-4r. Thanks for those measurements. I got the shifter used with no brackets so I figured it might be easiest just to fab my own bracket that still activates all the stock column stuff. I'll use those as a starting point and tweak it from there. Thanks again, james
I have a B&M shift lever. Just the lever. Let me know if you need it still. I am going to a stock one.
Let me make sure I have a stock one, take a pic and get right back to you.
