Looks like my gen 6 DFI has given up the ghost.  At least I think that's the case.
Here are my issues:
1) The throttle follower seems to reset to the wrong position causing the car to stall (this is intermittent).
2) I think one or more of the injector drivers are not working because I checked the #2 spark plug and it looks like it hardly ever fires. The engine has good compression and I checked for the possibility of a flat cam. Also, I changed coil packs and the ignition module I'm using seems to be in working order. I noticed that at a certain amount of load causes the engine to missfire. I checked for electrical shorts from the harness to the injector and couldn't find anything wrong.
3) I installed the DFI into my other GN just to see if it's the computer and it runs like crap on that car.
4) I also switched to a new injector harness and that didn't seem to help the situation either.
5) On most cold mornings, while warming up, the car definately missfires until I drive a few miles and then it clears up. But, now I get a missfire under partial load to WOT.
6) At WOT, the boost needle fluctuates rapidly (13 to 15 psi). The only time I've seen this before was due to a blown head gasket. But my compression is OK. I will schedule a leakdown (I have a 10 month old baby girl), but I want to eliminate all probable causes.
I will probably go back to the stock computer and see if it's something else in the wiring.
The mods on this car are: TE54, 72lb injectors, mild cam, ported iron heads, walbro 340, 489 rwhp at 19psi of boost.
			Here are my issues:
 Set the wot correction to 100% and the gen 6 will try and maintain the a/r ratio set in the lm-1.  Instead of 14.7 you can set the 500mv set point to 11.5 or anything you want.
