jarredsoon
- Aug 9, 2007
Ok so I have a stock car with 42 inj and TT chip.
Scan numbers are all within normal limits, 128 INt and 126 Bl
af is 5 at idle
tps is .42
when I first start the car it ildes fine and the iac is 175
when the temp reaches 165 or higher the iac drops to 0.0 and rpm riase to 1500-1700.
I did a search and unscrewed the throttle blade screw and nothing changed, I shut the car off for ten seconds and checked again.
I do not see any vac leaks before or after the maf???
Also I looked inthe TB and no deposits and very clean.
Thanks,
Jarred
af is 5 at idle
tps is .42
Thanks,
Jarred
