I have my IAT plumbed into the intake manifold (TPIS MiniRam2). Should it be in the ducting leading to the TB instead?
It seems that the IAT in the intake would soak up more heat than the air passing thru the manifold. My reasoning is, the air is moving and the IAT is not, therefore the IAT should soak up more heat than the air because the IAT is constantly physically touching the manifold. But the air is merely passing thru...
Am I wrong on this?
Thanks,
Owen
Am I wrong on this?
Thanks,
Owen
