With the current popularity of the distributor swap, I like to see what you guys think about whats available out there in CD boxes.
I know the majority are using the 7al2. This box appears to be bullet proof and is probably the only thing MSD sells that actually works.This box has no real features and when looking at the numbers ..Like spark output and coil voltage it looks a little low. Plus this bastard is 400.00 new !
In comparision the the mallory VII s has 2 built in rev limiters, digital display on the unit with selctor buttons. There is no need to buy anything xtra for it, unlike the 7al2. It has both higher spak output and coil voltage than the MSD.
http://store.summitracing.com/default.asp?target=/egnsearch.asp&N=400249
The Crane HI6R box looks pretty stout when used with their LX92 coil. It has a built in rotary switch selected rev limiter. It has way higher spark output than both units and equal coil voltge to the MSD. It also appears to be more compact...Both coil and box can be had for less than 350.00
http://store.summitracing.com/default.asp?target=/egnsearch.asp&N=400078
Im afraid to ask this ...But any opinions?
I rather not give MSD any more of my money after the DIS 4 fiasco.. :frown:
