- Feb 14, 2002
She quit on me today at WOT. I had to shut it off while coasting and restart.
It's been acting up a bit recently and seems to be getting progressively worse.
Weird symptoms leading up to today:
-small WOT KR that will not clean up with tune
-ocassional spark advance "dip" during normal driving, very brief spike from 40deg (normal) down to 30deg.
-lost RPM signal at WOT last week. Replaced crank trigger due to that incident.
Stock original ignition, Magnecor wires, NGK plugs, stock ECM with low Z drivers, TTSD computer chip. As mentioned above, brand new crank sensor.
Today it never lost the RPM signal, and datafile shows timing commands and injector pulsewidth commands, but never the less she quit running and I had to shut off and restart.
Data files shows a brief WOT, then the cut-out and me letting off, then tapping the pedal a few time to see if it was still running (it wasn't). After key-off, she started right back up and ran fine all the way home.
I think the 25 yr old stock ignition is giving up the ghost. What do you guys think?
Might be time for a Bailey TR6?
