Chasing a hot idle oil pressure issue... I'm looking into pulling the pan and plastigauge some bearings..... possibly rolling in some .001 bearings where needed. (Engine is a fresh build....only 1 hour or so of run time). Crank was used...std-std from a junkyard engine that I had polished...then new std bearings installed.
If the rods/mains clearance turned out to be .003... I could slide some .001 bearings in there with the engine still in car..
Anybody have any words of wisdom should I go that route?
