turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
I have a TE60 than may or may ont need a rebuild. I've never rebuilt one but I thought I'd try my hand at doing so.
I know I can order a kit but my question is:
With all of the caked on build up from never being rebuilt, is there a recommeded procedure such as hot tanking or acid dipping before actually rebuilding?
And...do I really need to rebuild? -there is no shaft play in any direction however, when I manually spin the wheel on the DP side... it makes a sounds such as if it were ever so slightly binding on the caked up material (like running a blade across that material that Catalytic convertors are made of..) Is this normal?
TIA
TIA
