injection, chip, regulator upgrade from stock?
GNguy198687
Hi guys/gals, Dan in Scranton Pa, new here. My stock injectors with 100,000+ on them are bleeding down slow when I shut car off and I want to upgrade any way. Does anyone sell an upgrade kit of injectors, regulator, chip and other related items as a whole which all work well together? Sold as a "matched kit" I guess you would call it? Any info would help. Thanks
Welcome Dan, Mike at fullthrottlespeed should be able to supply all your needs and Mike is a very knowledgeable guy as well. Let him know what your goals are and he will be able to help you out w/the necessities.
If your fuel pump is stock or unknown you will want to change that as well as a hot wire kit to go with the pump...This will be just as important as the other mods you mentioned...
I would grab 60lb injector and chip combo from Eric at Turbo Tweak. Then get a regulator, fuel pump, and hotwire kit all from Eric at Turbo Tweak as well. One stop shop and shipping.
