Jan Larsson
- Nov 22, 2001
Building new engine, had all machine work done and running a new comp cam roller camshaft. New after market HV front cover, before installing front cover did some blueprinting of oil passages and also made sure the cam sensor installed properly and lined up with the oilpump shaft without any issues. Cam sensor could be pushed in with normal resistance from o-ring as expected.
Anyway got everything back together, cam with proper end clearence etc.
Trying to install the cam sensor (without using any force at the moment and also turning the engine slightly to alighn gears) I only get it down so far (all of o-ring down and a bit more) but can seem to push it down carfully wiht my hand any longer ....
Do I need to push really hard on it to get it all the way down or do I have some other issues????
