Madmustard
- Nov 16, 2002
car is an 84 gn.either has a 86- 87 intercooled motor or had the conversion done before i bought it.Everything was fine-no problems.Switched to a New walbro pump,regulator etc. now my battery is dead.Bought new battery-ran elec test and cant proceed to check elec system b/c says "noise in the system".But everything was off w/ out key in ignition.so does anybody know how to tell if I have a short in the system from the fuel pump.?I used the wiring pigtail provided in the pump but maybe I pinched a wire-but I was carefull and dont believe i did...
So my question is :1.Is the wiring different on an 84 gn vs 86 and 87 and how do i tell if this was switched or not in this conversion?
2. I checked the elec wiring with the car off with a test light-no current being drawn at wiring harness to pump at back of gas tank. checked with the key on-no current to the pump.With the car started and running obviously there is current...
HELP!.Car also noticeably has a miss at idle.Miss while being driven.And completely cuts out when floored.Fuel press is 45#s with vac line off at idle.
