installing brake pedal........
hang10
old surfboards wanted!!!
What a pain in the ass.......doing a vacuum conversion,all the old stuff came off easy,but have been trying for ever to get that top bolt mounted on the new pedal.The seat is removed but at 6'2" 235 lbs i still cant get my hands up there!!!!!! I was reading in the archives that some people have done this swap in less then an hour!! WTF !!I am getting ready to take a sledge hammer to the dash. Sorry.....just venting! Kurt
Just for the record (and to benefit those who use search) -
It's ALOT easier to remove the whole bracket from the car THEN swap the pedal.
VACUUM VS HYDROBOOST
JUST A NOTE....THE HYDROBOOST CONVERSION USES THE SAME BRAKE PEDAL AS THE POWERMASTER, AND DOES NOT NEED THE PEDAL CHANGE. IT BOLTS RIGHT IN! IT CAN GENERATE 1400PSI TO 2000 PSI WITH "NO VACUUM" THANKS. YOU CAN SEE IT AT POWERBRAKESERVICE.NET
