interesting numbers
I hope that penny doesn't slide down in there! lol
I can see that it's some decent HP gains for sure with the porting. Did you do this yourself?
Yup! still got the penny. The pics above were of Gary Wells intercooler on his white limited. I also ported (myself) my V4 SLIC on my mid ten second GN.
Mike Barnard
we do have it all and will try to do that and some more testing over the thksgiving holiday--------but we just got a prototype of Bob Baileys trick 6 coil pack to test-------its going to be pretty hard for SloGN and I to tear ourselves away from that for a while :) ..................RC
Ok guys
I went back out to Richards place and did some more work on Mark's HA intake
flow numbers
Mark S (84/85) HA
1-134 2-148
3-153 4-117 -----124 after doing some extra porting i ported it the best i could get to without cutting it open 130 Cfm. But other wise it's still a complete intake zip tubes and all.
5-156 6-146
Pat- that's a pretty significant improvement. :cool:
See you next Friday night for the big weekend thrash on my GN.
Carl
Richard
Nice test.
I would also post if the intake was ported to a 1200 Fel-Pro gasket or the stock valley pan gasket.
I would also try to ahold of a Stage 2 intake. Sorry I don't have one.
Billy T.
gnxtc2@aol.com
any #'s on cottons front mount?
i think i have one of those in the shop------i will check this weekend
did a champion "biggie" that was ported by GBP----------had champion plenum and accufab throttle body
total flow was a whopping 784 @ 28"
average port flow was 283 CFM
277 #2 #1 273
285 #4 #3 288
289 #6 #5 289
Ok guys
flow numbers
Mark S (84/85) HA
1-134 2-148
5-156 6-146
Howdy guys
Well i fianlly got some more time to spend on Mark's HA intake. I finally just cut the bottom off of it. I now understand how the Zip tubes and air flow paths really are.
So i using a milling machine i milled out the center divider and the zip tube walls. The cutter i was using didn't allow for me to mille the center divider wall completely out. But it's about 3/4 of the way down.
The champion intake has it milled completely away.
The final flow #'s are
1.---187 2.---187
3.---188 4.---193
5.---188 6.---187
Avg Flow 188
When i first started #4 was the worst flowing and i actually ported on it some more and got it upto 130 before cutting it open. Now after i milled it and ported it it's now the best flowing lol. I actually cut thru on a small portion of the #4 port on a sharp edge that i had to weld up and shape back down.
The other's i simply just touched up on those over what had already been done.
The next HA intake i do i'm simply just gonna go ahead and cut out the zip tube and center wall. Then flow it and then port it accordingly. Since i now know what needs to be done.
over the holidays Jim managed to find his hemco plenum so we set out to flow it on stock intake to see how it compares to the rjc plate or a 1.5" spacer.
stock intake/plenum
1-161 2-157
3-175 4-160
5-177 6-172
stock intake/plenum rjc plate
1-167 2-163
3-169 4-170
5-163 6-165
stock intake/hemco
1-171 2-167
3-174 4-176
5-170 6-170
stock intake/1.5" spacer
1-166 2-164
3-173 4-171
5-172 6-170
Stack them Pat. The way you've got it listed makes no sense to me, but I'm just slightly dislexic. LOL
My minimal input in bold below.
stock intake/plenum
20 CFM between the Highest #5 and the Lowest #2
Average CFM 167 Total CFM 1002
1-161 2-157
3-175 4-160
5-177 6-172
7 CFM between the Highest #4 and the Lowest #2
Average CFM 166 Total CFM 997
1-167 2-163
3-169 4-170
5-163 6-165
stock intake/hemco
9 CFM between the Highest #4 and the Lowest #2
Average CFM 171 Total CFM 1028
1-171 2-167
3-174 4-176
5-170 6-170
9 CFM between the Highest #3 and the Lowest #2
Average CFM 169 Total CFM 1016
1-166 2-164
3-173 4-171
5-172 6-170
