SignUp Now!Since you have a power logger, why not record fuel pressure at the same time? The sensor is a bit expensive, but well worth it to me anyway. You will use input #4 and configure it as a 100 psi sensor B. You might get a discount If you say norbs sent you, or maybe he will jack up the price, LOL Kelly is great to deal with.
I am impressed with your numbers so far te44 is a great little turbo for the street.
Pressure Sensors - Transducers
WB-762 is the sensor you need.
I will check fuel delivery. I didn't want to buy a camshaft anyways. Current tires are 255/60/15. I have been looking for MT 275/60/15. Funny you say add higher octane because I just found out Sunoco station down the road sells 110. Current timing is about 21.5* so certainly room to cautiously move it up. I had plans to go to dragstrip 3 times this year and each time something came up so I had to cancel, but I know I need to get there. Thanks for the comments Bison.
Well looks like you need to add a bunch more fuel, and based on the WB data, I would say its misfiring under high boost. I would say the injectors are big enough but your fuel pump is not keeping up maybe. BLMS are at 170 maxed out the injectors are close to 87-90%. Or turn up the fuel pressure 5 psi. WHen you start seeing the a/f ratio bounce every bounce is a misfire. I have learned from experience. Coming up on boost it went lean and knocked, not a good thing. You may want to richen overall system fuel on the chip, but the duty cycle seems high its a fuel problem somewhere.
I remembered today that a couple of weeks ago I disconnected my Red's Volt Booster because it was making my Razor's Alky go "crazy". The car ran much better but could this have had a negative effect on my fuel pressure? I looked at previous logs when the VB was connected and my BLMs were fine at 128 at high boost. Does this make sense?
Today I raised my fuel pressure to 48 from 43 and logged a run down the highway and my BLMs were 159 down from 170 at the top end. Still far from 128. How much can I raise the FP?
Ill be testing a 6152 soon.......
Bison,
Did you ever get a chance to test this turbo?
Thanks for sharing the knowledge and test results!
Bison,
Sorry if I missed it earlier, but what fuel pump are you using on the test car? Stock fuel lines I assume?
Double XP/stock lines. It doenst need both pumps on the dyno up to the 501whp max its been to. I tried with the 2nd pump off and no increse in duty cycle anywhere. This may not be true when factoring in g-force. Ive been up to about 670whp on a single 340@14v, 10.8:1 a/f with 30 gph worth of alky flowing at the same time on the dyno. At 680whp the duty cycle jumped abruptly. You can not use dyno hp to evaluate the effectiveness of a fuel system since there will always need to be more pump to deal with the g force when racing, especially if large lines are used or the suction side of the pump is not behind/parallel with the cell/tank. Ive seen cars with suctions that required the pump to suction toward the front of the car. That would not matter on a dyno but will cavitate a pump really fast with a hard launch.
I have a car here with ported iron,212 roller that has gone 10.30s with a 6776 we ca test some turbos on.
I will be putting a champion ported head 212 roller car together tomorrow that was dynoed with a TA 49 and its getting a TA 6265 Billet Wheel BB turbo now and redynoed.
So we can see the difference on a more modded car.
The test wont be back to back though but same car.
Keep it coming, this thread is a big help!
