How about the smaller billets ie; the 5857E and the 6057E.
Send them in. Backpressure will likely be a problem with those on this engine.
SignUp Now!How about the smaller billets ie; the 5857E and the 6057E.
Its surprising to some how far the old 76 trim turbos will go. With higher compression and some boost/timing, and the correct cam in the right spot you could wind up making another 75-100hp more than an engine with everything else the same except the boost pressure, timing, cam timing, and compression ratio. None of which are visible from the outside. You can go from a turd to an animal by paying attention to these things. Most on here seem to adhere to the 21* or less timing, sub 25psi boost and have no clue about cam timing or what increased compression ratio will do. So they are over turboed, under convertered/wrong converter, not a clue about the cam, and their tuning off a narrow band. Therefore their performance is lacking. There is a point where timing wont help but its definitely above 21* on these engines. Its possible to get it to work with those obstacles but it will take a lot of quarter passes to get it sorted out. I dont have time for that. There isnt even a drag strip within 100 miles of me. 9 out of 10 times its best to stay with a really small cam and let the turbo do the work. Not going to happen at sub 25psi with an 8:1 engine.Makes sense- when Don Cruz tore my 109 down, he said it was not going to last much longer. I had way too much timing, probably 30* or more with the chain it had, plus the align hone was high and I was running very milled heads, which means more compression, and the cam gear was not right on the timing cover. No wonder with just bowl porting and a little cam it was shot out of a cannon with a P trim TE45a.
I would like to see a 6776dbb tested
Do u think the 3bolt big ex housing would start to benifit on the tested car if u matched it with a 3.5in dp and went open dp?
What you think bison? Worth the money?
Cant say what is ideal until you have tried several things to find out which worked best. No need to play with cam timing to run 10.50. Probably around 9.3:1 with a 212/212, 21-22psi.So whats the ideal compression ratio/cam and cam advance for someone wanting to run 10.50s on kill with a set of ported big valve irons but without running ridiculous boost pressure?
This is part of what I wanted to talk to you about Brian.:biggrin: Start a thread on cam timing ect and I'll be more than happy to subscribe.The turbo is only part of the equation and I have that pretty much figured out but would like to bounce some theory around related to cam timing and compression to get a better idea of what's possible.:smile:
Ill do it but i cant eat the labor on that one. Way too many things to do. Every cam tested would need to be checked after install. Being conservative id say about 4hrs per cam and 2hrs per cam timing adjustment. Not to mention id probably need at least one more set of pushrods around.
I can work with a local engine dyno to do this,would be way easier.
Bison, if you had to get the current long block into the 570-600hp mark do you think it could be done? What boost level, timing, and turbo?
Is the turbonetics 6680 turbo the same as a 66-Strim?
Datar
Some good stuff here guys... Keep it going!!
Brian, what PTC pump# are you running on this "test car"?
Thanks,
K.
Even if I go off what VPE chart of 223cfm @ .600 that still sucks IMO for an FI car. I've argued this years ago with a Vendor that we've been let down if buying a set of Aluminums that flow 230 out the box is good enough.
