SignUp Now!Hi Charlie, i'm sure you would need a license to buy it because it would have to be bought from a Heating / Air supply store and it comes in a 30lb jug. When I done research years ago on it and compared the cooling properties to r12 I was amazed to see the RB 276 having better numbers. After installing in in my GN as a test it worked Great!Tell me more about the RB276 please Scott. Is it restricted like R-12 so I'd have to get it with my lisence?
I think if you cross referance the number 414B with RB 276 they just might be the same! Most refridgerants have two numbers, I don't know why but most of them do. I will go check my books again now if I can find them. I also have RB 276 in my little Isuzu p/u and have seen 34* air coming out of the vents to the point that the back window starts to frost in 90* weather!!Scot- 414B also is 20 degrees colder than R12,a direct drop in for 12 & 134a-with no oil change about $200 for a 30 lb can-how much is the RB276? havent heard of this one but have been using HotShot 414B for about 5 years with 0 problems-35 degrees inside air temp on a 95 degree day in august-you can see my breath in the car.
There has been something better developed and that would be RB 276 / 414B!!After much research:
1. r12 cools best (I have to research 414 yet) & the TR is designed for it & also has least permeability problems.
2. 134 is not as cold as r12 & has permerabilty issues & the TR was not designed for it. When 134 first came out, NONE of the then new cars would stay cold at a long red light. The compressors had to be completely redesigned to keep cold at a long red light. Don't ask how I know.
3. 123 (the latest gov't junk) isn't as cold as 134 & has double the permeability issues as 134. 123 needs more compressor development than 134.
It's your car, however, I'm going with r12 until something better is ever developed!
Keep us posted if you give it a try.
SW.
