tobuyitright
- Aug 29, 2005
I just made a deal to purchase a set of new TA performace aluminum heads and roller rocker 1.65 from a fellow board member. Heres my question. I am gathering parts for my winter project. Have in boxes ready for install, walbro pump, hot wire, PTE front mount intercooler, new TE60 turbo, TA SE Heads probably need to think about a cam or may not depending on board opinions cam i could use some help with.... but short block is stock. I have to get some injectors as soon as I can figure out how or what is needed to get the fuel management system where it needs to be.
Ok here is the questions I have, Im buying the heads, to long term use them on my stage II block. However, I am planning that for a year or two down the road, for now want to see how well I can get the 3.8 to work for me. Am I CRAZY for putting these heads on a stock bottom end, motor only have 30k on the clock. Thanks for your opinions. Scott
P.S. I am trying to get the car into the 11s safely! (With this 3.8)
