I pulled the plenum off to clean and paint it.I found that it had a spacer inbetween the top and the base intake.Also looks like the base might be ported.
The top part of the intake has a diverter plate welded in it(to round off the back and direct air into the intake)
Then a spacer plate that the hole is smaller than the upper intake/lower intake.Looks like it's some sort of restrictor plate.The plate is made out of aluminum.
Is this normal?
I'm figuring there is alot more work done to this car than I thought there was.It runs great,barks or spins the tires on all shifts and pushed 320 rwhp with only 14lbs of boost with the t44 turbo.
Any help or idea's would be appreciated
Is this normal?
