I noticed this today as I was looking over the new crank I just settled into a block for storage and noticed the weird flaw between the number 3 and 4 rod journals. The crank is untouched at this point. Anything to worry about? I need to inspect the other webbing between 1/2 and 5/6 yet but they appear to be ok at this point.
On a side note: this is a 4340 steel crank and I had a set of .020 over bearings laying around so I set it in the block with those bearings and gently hand tightened the main caps just to keep it from falling out if I rotate the stand. The crank doesn't sit all the way down, but very close. Any problems with this? I'm throwing away the bearings anyway, but I don't want to hurt the crank but do want it stored in a block.
TIA
TIA
