Is torque convertor slipping
evil666
My brother has an art carr 9 inch torque convertor which is supposed to stall from 3000 to 3200 rpm. When we went to the track today he was taking off at about 6 lbs of boost and the stall would be at 3400 rpm. Another reason which I think it is slipping a bit is because before finishing the 1/4 of a mile he shifts into overdrive and only drops about 100 rpm from third gear(5300 rpm in third -shifts in overdrive 5200 rpm). He did his best et ever today which was 11.80 at 113 mph with a 1.60 60ft time. On another day he did a best mph of 114.74 with an 11.87 et and 1.72 60 ft time. I would really appreciate having some of you guy's advice on if his torque convertor is slipping.
THANKS MARCO
My brother’s 87 Grand National t-top (92 000 km)
Stock block with trw pistons and 30 over, stock heads, 210-205 lunati cam, 65 mm kenne bell TB and plenum, 9 inch 3000-3200 stall art carr convertor,22 ½ boost, 94 octane with 100% methanol with smc alk injection, thdp, hooker 2 ½ exhaust, 42 ½ lbs injectors, Armstrong 100 chip, ESP front mount IC, 26 BY 10 M/T ET STREEET TIRES, 3800 LBS race weight.
BEST ET= 1.60 60FT- 7.47 1/8- 11.80 ET-113 MPH
BEST MPH= 1.72 60FT – 11.87 ET AT 114,74 MPH
