ISAC a/f control?
VIN7
If my ecm is closed loop wb controlling a/f to 10.8 with gasoline does that mean if I set the ISAC to a/f control and 10.8 that it would NOT be spraying alky since the 10.8 is already being met?
Mike
not necessarily,
but you only want one device doing closed loop control at a time.
If your ECM is closed loop, then don't run the ISAC that way.
B
