ISAC controller latest software
Dave,
With the ICC open go to the "monitor" tab, then right click in the graph area. You should see option to load log, then click on the ISL you want to view.
Mike
ISAC rocks! Setup: 6262 dbb SP cover, THDP, HD wastegate, Ingersol Rand solenoid, ISAC controlling the solenoid.
email me that log, I'l like to peek at a couple things. The ISA file also, if you have it handy. (quicksave saves both)
Looks like its working well.
Bob
The variation in the red line (target boost) in the screenshot above was just me tweaking the trim knob before I went WOT.
I'm not sure what vendors are carrying it at the moment, Shane (SGRIM) would know better than I.
Bob
Gbodyparts has some and I have some. They can be found on the gbody website!
VIN7. Mine is a similar setup. Mind sharing yoru Boost Control settings?
No problem. The tps and rpm enable settings are like that because I was testing the solenoid with Key on engine off.
Also, now that I looked at it the target boost is varying because I have the tps/%boost configured as such.
Mike
