Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
I am at odds. I have replaced lines, reservoir, pump and Ill be dipped if I can keep the thing from spewing out foam from the reservoir
I have now replaced the pump, ran all new AN-6 lines. Even replace the feed fine to the pump from reservoir.
Now I will state this. THIS IS A DIFFERENT RESERVOIR. This is one that is all metal from from an Astro Van.
Any ideas? Is the original Reservoir sealed?
