Joe Gibbs Racing Oil
1987 Grand National
Has anyone used Joe Gibbs Racing, Driven motor oil? They claim high zinc, phosphorus, and sulfur. It's expensive but if I don't have to buy the little bottles of ZDDP than it may not be that bad. I am currently running Brad Penn with one bottle of ZDDP. What do you guys think is best?
i have been thinking about switching to the brad penn oil myself, the engine shop ill be getting from recommends i use a 20w 50 weight for my buick grand nat, considering i dont have the best oil pressure either, around 15lbs hot @ idle but it does climb as throttle climbs,, what ya'll think??
10w30 oil. :mad: 20w50 is like molasses, no need to run that heavy an oil unless your bandaiding loose bearings, or loose gears in the oil pump.
1/2 bottle ZDDP with Brad Penn Oil.....a full bottle is too much.
If you do a search, I believe that you'll find that's what Richard Clark and Dennis Kirban both recommend. That's what I run and have not encountered any issues.
I don't like the idea of adding zinc. Let the refinery do the blending. I definitely wouldn't add a ZDDP additive to either of these oils. They're blended to give your motor the protection it needs.
Anybody compare the quality of both oils? I am not telling that brad penn oil is not good but i want to know the extra advantages of other brand if it is expensive so there should be a other advantages also.
I don't think you could measure the difference. Use one and stay with it.
Number ONE is, ALOT of the new brand name oils claim to have ( HIGH ) zinc and phosphorus levels in thier oil. BUT do you know of ONE that gives you any numbers? is it enough ? It seems like the Brad Penn might have high enough levels of it from what Bill at Webber has posted here.
I have to ask...can there be too much?(zddp) i imagine its just overkill with BP or JG... I read that it(zddp) can degrade some? So i felt a little extra might be a safe-gaurd. Especially for me running 110 seat pressure and a flat cam.[/quote]
Great info re;PPM...thank... i learned something today:) Will save me some $ too.
