C
Chris Taylor
Guest
We took my friends 86 T to the dyno tonight. It was 90* outside and 98*-100* in the dyno room.
This is a stock 30,000-mile unopened motor. This car has the following set up:
PT51
V2 front mount I/C
50# injectors
Hemco plenum
3” DP (open dump)
Volt booster
340 Walbro with hot wire
Ram air
JL race chip
Level 10 shift kit
JW 10” 3200-3400 converter (non Lockup)
160* thermostat
We were running 26-27 psi of boost with 110 oct. race fuel.
All runs were within 2-3 hp. We made six pulls with the best pull of 432hp @ 526tq. This was with 26# of boost and no knock. The dyno guy said the car would have made about 25-50 more hp if the barometric pressure and temperature had been better. He was figuring about 22% hp loss through the driveline. Is this a correct calculation? I thought these were good numbers for such a hot evening and poor conditions. Not to mention a unopened motor.
This car runs 6.99-7.0’s in the 1/8 @ 100-102 mph.
PT51
V2 front mount I/C
50# injectors
Hemco plenum
3” DP (open dump)
Volt booster
Ram air
JL race chip
Level 10 shift kit
160* thermostat
