SignUp Now!Originally posted by OneLethal87GN
I lose pressure after shutting off as well, but not suddenly. It takes about 10 minutes or so. Also, my fuel pressure gauge reads in the mid 20s at idle and rises accordingly with boost. My O2 counts are low 800s so I know it's not running lean. The pump is new, injectors have about 2 years on them, and the regulator has about 3 I think. I have tried adjusting the pressure with the regulator, with little luck. I can raise it with my K-B boost-a-pump though. Regulator my problem or just bad gauge?
Originally posted by qwic87gn
The 009's are brand new pte. Everthing was fine until I changed out the tomco with these.
More than likely its going right into the crankcase. These injectors were flow matched and performed great (supposedly).
Originally posted by Steve Wood
pull the plugs and see if you have a wet cylinder(s)
You may have an injector that is stuck wide open. Sometimes happens with new injectors.
