MNcarbturbo
What's Fuel Injection?
- Mar 9, 2009
Its back together. Need a few hours of misc work before it goes in, mostly wiring and converter bolts. Fuel rails is just -6 extrusion from http://www.rossmachineracing.com/dash6.html that I threw on a mill. Used a 3/4" endmill and cut an 8 degree notch every 4.25". Then I went .300" deep with a 14MM endmill, and then drilled a 1/4" feed hole. Chamfer the entry, cut to length. Tap ends with a 9/16-18, used -6 ORB hydraulic fittings since I hate blue/red AN stuff and hydro stuff is easy to get. Then brackets got built, drilled some holes, put in some #10 cap screws, tapped, assembled, done.
REAL close. The plug is turned down and the threads overlap the feed hole just a bit but 1/4" is more than enough to feed 1 injector. It cant get any shorter.
Had to trim part of the dust shield off the alt, fitting hit it and it couldnt go shorter
