Lambda on PL
TLI
Is there a way to switch the display lambda on the PL? I am running E-85 and would rather use lambda #'s instead of trying to convert the gas a/f to E-85a/f and making a mistake and running lean.
not currently, but you could connect the wideband to analog 4 or 5 and scale it however you want.
B
but everyone on here tends to talk about e85, and tune with gasoline scaled numbers.
B
B
This is true. So if there possibly a later upgrade for the PL to read lambda? I guess it is all a conversion off of the lambda # anyway.
making the PLC software read lambda is not too hard, making the Scanmaster read lambda takes a bit more work.
What wideband are you running?
Bob
AEM (guage type) from Eric Marshall. I do not have the scanmaster though.
It can be switched between gas AFR or Lambda. I have it in the down pipe on the work bench now so it is not back in the car now.
