Mar 26, 2012 #1 T TLI Member Joined Mar 29, 2006 Messages 47 Is there a way to switch the display lambda on the PL? I am running E-85 and would rather use lambda #'s instead of trying to convert the gas a/f to E-85a/f and making a mistake and running lean. Thanks
Mar 26, 2012 #2 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 not currently, but you could connect the wideband to analog 4 or 5 and scale it however you want. B
Mar 26, 2012 #3 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 but everyone on here tends to talk about e85, and tune with gasoline scaled numbers. B
Mar 28, 2012 #4 T TLI Member Joined Mar 29, 2006 Messages 47 TurboBob said: but everyone on here tends to talk about e85, and tune with gasoline scaled numbers. B Click to expand... This is true. So if there possibly a later upgrade for the PL to read lambda? I guess it is all a conversion off of the lambda # anyway.
Mar 28, 2012 #5 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 making the PLC software read lambda is not too hard, making the Scanmaster read lambda takes a bit more work. What wideband are you running? Bob
Mar 28, 2012 #6 T TLI Member Joined Mar 29, 2006 Messages 47 AEM (guage type) from Eric Marshall. I do not have the scanmaster though.
Mar 28, 2012 #7 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 is it reading Lambda or AFR? B
Mar 29, 2012 #8 T TLI Member Joined Mar 29, 2006 Messages 47 It can be switched between gas AFR or Lambda. I have it in the down pipe on the work bench now so it is not back in the car now.
