Largest Turbonetics 3 bolt?
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
I have a 62-1. What are the larger size Turbonetics 3-bolt that will fit my ATR headers and 3" down pipe? I have a CAS V1 FMIC and flexible 4" inlet hose.
Conrad
Ive got an old T72BB P-trim 3 bolt on my car. Spools really fast with a 9" 3000 stall. Just dynoed with it.
And what did it do on the Dyno? Do you have a sheet , would love to see the HP under the curve on this setup.
Jess
Would you call that a 'well into the 10s' combo?
Yes, as ive gone into the 10's with a friends car with less than that. His car was 3700 lbs with driver and bone stock suspension except poly bushings in control arms. Mine will be around 3600 with driver after i put it on a diet. I had a similar combo long ago that went 6.70's@102+ in the eighth with a small PT54 turbo and less compression.
