SignUp Now!yep thinking about going back to gasThis e85 stuff really complicates things doesn't it? Lol
or Ginger AleIt would be soooooooooooo much better if ethanol had water in it instead of ATF approved stuff that really has no business mixing with alcohol.
I use a fuel additive in both my e-85 cars and most of the local owners do as well.
I also noticed when I spilled some E85 on my pants, that it evaporated rather quickly. I know when heat is added, the evaporation rate increases from this phase change, so one has to think that the E85 is also getting vaporized out with the water while normally driving.
Well, im talking about the crankcase. If the oil gets hot enought to make water "boil" out, then it will increase the evaporation rate of the E85 that already has a high evaporation rate. I wonder if E85 has a lower viscosity than gas and getting past the rings like #% more under boost....Or like stated above, there is much more fuel in the cylinder raising the probability of it getting past the rings.HmmmI wonder if having a fuel return or a returnless setup effects this at all. I see what you're saying though.
Combustion makes a lot of water no matter what kind of fuel your using. Gas, alcohol, diesel.
X2
ethanol
C2H5OH + 3O2 --> 2CO2 + 3H2O
Gas
2C8H18 + 25O2 --> 18H2O + 16CO2
That water goes into the exhaust and into the blow-by. If the exhaust pipe is cold, the water condenses. Same thing in the crankcase. If the crankcase is cold, the water in the blow by gas condenses. It evaporates later when the engine warms up.
