I got the cnc heads back from machine shop after they repaired the 1 bad valve & did a valve job. Mr. Anderson stated that that 1 particular valve was to tight in it's guide. my queation is- do I have to re-check preload? as basically same thing happened to GN#1 on same #2 cylinder. which I put back together & have had no issue's at all, as a matter of fact it runs alot better. :biggrin: so issue with GN#2 would be no different, right?
