Royal-T-Ltd
- Jul 12, 2003
i have been working on the car for a few mos. [more like 6-7] ... with lots of delays from powder coaters and parts people... well i finally got everything and have been wrenching 3days straight and decided to make it to BG.... well i am here..... with some issues
1) i have developed a weird and annoying rattle, to me it sounds like its coming from the tranny but i did not do any work in that area... i double checked all the TC bolts and they are nice and tight.... seems to go away in Neutral and while cruising
2) i have been experiencing a hard start problem... dont know why - never had this issue...FP is good and i hope it is getting good spark.... which leads me to
3) replaced the Ignition system with Bob's TR6... dont know if its related but - SOMETIMES - while cruising on the highway the tach signal stays at 1000 and then randomly shoots up to 3000 or 2000...it looks like a graphic equalizer... when this happens it will die at idle..... other times the tach signal is fine and it will idle fine
help a brotha out....
oh and the things i did were replace Heads/Gaskets with some stock ported i had laying around, replaced rocker arms and installed the TR6...and removed EGR - everything else was just removed for detailing
aaron
aaron
