Recently had a B & M Launch Control installed(line lock) and its not holding weren't a dern. I tried new shoes on the front but they didn't improve the situation. Basically it will not hold the car even if I overpower the rear brakes and get them to spinning. I contacted Summit and got the answer that because the front brakes are disc it will not hold which I said was a bunch of BS cause they are being used all over the place. I also asked if this item is not gonna work with front disc brakes don't you think the manufacturer ought say something, ya think? I'm just trying to do a burnout without heating up my back shoes. I'm looking for suggestions. I didn't want to start throwing money I don't have at it. I have no idea what to do other then make sure its bled properly and possibly change out the hoses and calipers. The brakes seem to work fine with no pulling to one side or the other even with hard stops. The car has a rebuilt powermaster unit on it with no apparant braking issues other then there does not appear to be sufficient pressure before applied when the line lock is set.
