SignUp Now!Originally posted by Warp6
[B......- I'd suggest distilled water and about 2oz of RMI25 and a bottle of Redline's Water Wetter. I've run this stuff(WaterWetter) for 8 years with no problems. You can get it at PepBoys. .....! [/B]
Originally posted by SIXBANGR
Not streetable? I drove mine from Reno to Denver. I had an in line trans cooler to help cool the water. I used nothing but water.
Let's lead by example here and show Mike what "fast with class" is all about
Originally posted by turbodave231
I would like to point out that the Syclone and Typhoon both use a air to water heat exchanger and those are obviously streetable vehicles.
The efficiency of the exchanger is really the issue that you bring up, Turbodave. The question that you need to answer is if the lower delta T in an air to water intercooler is offset by increased efficiency in heat transfer.
Air to air heat exchangers will have a higher delta T but a lower efficiency (air doesn't conduct heat as well as water).
Originally posted by azgn
call ATR, they have exactly what you are looking for (if you care to part with $2K.....)
that said, if a car has one installed, it would be a very nice advantage at the race track if you can keep it cool
shoot, you guys have colder air in the dead of summer than we ever see! I would just once like to run my car in some sub 60* air to see what would happen!
even your old stompin' grounds (Sandyeggo) is better than us!
