Looking for interested buyers for a group purchase.
turbov6joe
Signal 1 J-12
If I can get enough interested parties to obligate, I can get braided stainless steel turbo oil feed lines. These are SUPERIOR quality with all pressed and/or crimped on fittings and angles, as well as high temp resistant lining. These are ~1" longer than other available lines. This allows for a looser fit and more options to route it down to the block. I had a prototype unit made yesterday and it is of GREAT quality! I had a similiar feed line that I bought from another vendor that the flair began to leak after little use...that's the reason I sourced out this feed line. I will be selling these for $30 shipped to the lower/mainland United States. Check around and you will see that this price beats any other. I will not make any moves on this for at least a week to allow buyers to jump in on this deal.
Boy, that didn't take long...you all know a deal when you see one!
Just so you all know. I'll check on the status of buyers regularly, but prolly won't post every time someone new jumps in unless there is a question that needs addressed. After about a week I'll run up the total and get back with each of you to finalize the deal...TIA.
I just thought I something I want to make clear. This sale is for just the hose and the hose ends. You will need to buy your own fittings that go into the block and onto the turbo.
Could you sell the needed fittings?
Sometimes it is difficult to find the correct fittings locally.
these lines should fit with the fittings already on the car right?? Please advise.
These lines have female ends and will not work with the factory set up. You would need an 90* male flair fitting coming out of the turbo and a straight male flair style fitting coming out of the block. This sale is for the line only! I do not have the time to pull my car apart to source out fittings to set up kits....sorry fellas! Any NAPA, O'Reilys, or Autozone has the fittings you need, it will take a few bucks and some of your time to get what your parts. If you change your mind about wanting a line, let me know. Otherwise I will let this thing ride out until next week and go from there.
Can you post some pic's of the prototype you have resived? and is there a posivilyty to have some draine lines too o mache?
