stock height 26"
SignUp Now!stock height 26"
I had a set of 3.08's but at the time with the 231 would cause premature pinging, so I took them off and sold them. Yes I will stay with the 3.23 for a long time.So you like what the numerically lower gear do for you? You'd like a 3.18 even?
yes it was.Too much load too early is it? (the early pinging)
knock is controlled by afr/timing and octane adjustments tune accordingly and you would be fine.If a car can potentially start knocking early because of this, would that be an octane/alky delivery problem?
the rpm climb rate will be affected.the 3.23 will take longer to rpm as you are decreasing torque off the rear end.And I still want to know how the engine discerns the difference between the early loading of the taller tires or the early loading of a taller gear.
absolutely as rollout is the biggest gainSince everyone here would run 39" tires if their car would allow them
The same goes with a taller tire? Or no.the rpm climb rate will be affected.the 3.23 will take longer to rpm as you are decreasing torque off the rear end.
yes you are changing the overall ratio by going taller on the tire.The same goes with a taller tire? Or no.
