robbyredneck
- May 31, 2006
any tricks or shortcuts to getting oil pump primed without removal?
SignUp Now!any tricks or shortcuts to getting oil pump primed without removal?
are you saying that you cannot use a priming tool or an old distributor shaft on a drill and get the pump to prime???--------if so that means only one thing-------the clearances in your pump are too loose and it cannot pull a reasonable vacuum enough to lift the oil from the pan into the pump-------if so you need to check the pump clearances --------you will never have good hot low RPM oil pressure if the pump cannot draw a vacuum without being primed...........RC
Maybe by "tricks" he meant a priming tool as he was unaware of them??
Still the best IMO. Altho popping out 6 bolts & packing the gears with vaseline only takes an 45 mins-hour & is an idea that always works so I do both.
it will guarantee the pump primes but it doesn't correct for too high clearances----------i quit packing pumps years ago when i discovered how unimportant it was if the pump was set up right--------they prime within 2 to 3 seconds every time---------but you can't get a pump right if you use standard gaskets--------all the now available GM gaskets and the aftermarket gaskets i have found are .007 to .009 thick-------makes it just about impossible to set end clearance tight enough without making your own gasket-------i find that sometimes they need to be as thin as 1 or 2 thousands...............RC
TA Performance sells those gaskets.
