- May 28, 2001
Take it apart.Red 2, plenum to intake is the leak point.
TB to plenum is sealed.
Now that it has cooled down, I checked it over and found the front drivers side stud was ripped right out of the threads on the intake, and passenger side front was loose, so maybe that one is ready to go to.
Remove the t/b & clean ALL the shit off the 2 mating surfaces, including the pulled threads at the bolt holes.
Set the plenum on the manifold and check for warpage with a very thin feeler gage.
Feeler on the intake, press the plenum with your hand. Feeler pull out? Mental note on pull req'd.
Try this at all around. If the intake is warped you'll feel it. That's what feeler gauges do....They feel shit!
Helicoil all the holes?
You said: "That's what I did. I put stainless steel inserts in, switched to studs.
Most likely the intake is garbage now, unless I want to try, most likely the intake is garbage now, unless I want to try drilling and tapping up another size and drilling out the plenum holes".
If you tried to put inserts into ruined threads, that's why they pulled out.
Drill it, tap it and Helicoil it. Done deal.
If that's done correctly, check your torque wrench.
An aside... This intake hasn't had the egr port filled has it?
Back under my rock.....
