crashedout1
- Feb 23, 2011
87 ignitinion swap 87 cranksensor swap 35lbs at fuel rail crank the car and boom! interrupter ring was bent a little straightened not perfect. But seems as if it clears sensor cam sensor turns but not sure it's right never touched since .car quit running never ran with new ignition. found. The plug was bad on module so I soldered directly to caspers plug n play crank car a little nothing. Maybe a slight fire. Crank again and boom! So I'm checking connectors and notice there's two relays on passengers side fender one the plug is melted the one towards the front of car hmm does this relay work the pump I unplug it and the pump still works does not prime though any inpu
t?
t?
