Ok, so I'm going to replace the stock setup on my '87 GN - finally. It has 55k miles on it and I want to go low 11's or maybe eventually high 10's (and I've been told I need heads/cam to get there).
The bottom line is which turbo/downpipe/exhaust combo could get me closest there (and how close could I expect?) with stock heads/cam and then IF I do end up replacing the the heads and cam, would still have enough smoke left to take me into the 10's? I would rather not buy twice IF I can get away with that so that's why I'm asking now but if need be, I can.
Will my 009's work ok with a low 11 second Turbo or do I need to go with 50's now and get it over with?
Of course the magic 'Catch-all' is that I want it to be easily streetable and if that means high 10's are out of the question, so be it.
A converter is a definite and the advice I've been getting is something around 2800-3000 stall with lockup. Suggestions?
I've been told a -60 is what would do the trick - care to tell me what you're -60 and combo is and would you do it again OR go another route?
Current mods are in the sig - basic bolt ons. Thanks for any and all responses.
