All my cylinders are
# 1 = 93 psi
#2 = 100 psi
#3 = 100 psi
#4 = 95 psi
#5 = 97 psi
#6 = 102 psi
Right after the rebuild they were all about 110 psi.
I have about 1,500 miles on the rebuild I did 9 years ago.
Last leakdown test check on the gn was on 10-11-06 which is only 600 miles ago. The readings were 7,10,15,10,15,11 percent for the cylinders. This is acceptable.
Normally I would think those compression numbers are very low, but they aren't much lower than right after the rebuild.
I tested with engine cold at WOT. I know guys are reporting 135 psi+ on stock engines, but on modified engines do people get lower numbers?
Thanks.
# 1 = 93 psi
#2 = 100 psi
#3 = 100 psi
#4 = 95 psi
#5 = 97 psi
#6 = 102 psi
Thanks.
