What do you guys think? Lower the front or leave it? And if I should lower it, how ie: coilovers, drop spindles, cut springs, etc, etc.
Currently the springs are stock OEM. TRZ upper and lower front control arms w/ 1st gen F-body spindle, manual steering. QA1 singles all around (yea, I want to change them to DA Afco BNCs). Tire is 325/50-15 M/T DR
Weighed the car w/o me.
LF-859 RF-843
LR-742 RR-779
Note: I threw a set of 1983 Camaro Z28 rear springs, gm part # 10018091, code: NNL (bottom pic) in back in May when I was racing in Bowling Green. The car ran a 1.34 60'. The tires were rubbing the inner rear wheelwells on turns. I also had a 28" front tire which made the car look goofy and have changed over to a 26" since then.
Note: although not a good pic, the 3rd pic down the car has the 28" front tires and the Camaro rear springs. The car is not strapped down tight, note the straps do hook in front of the rear tires.
Billy T.
gnxtc2@aol.com
LF-859 RF-843
LR-742 RR-779
Billy T.
gnxtc2@aol.com
