SignUp Now!I forgot to mention, you can get the howe lower ball joints to lower the front of the car another .5 to .75 inch if the springs don't lower it enough for you.
There are many lowering spring options out there. I installed Moog 5660 in may car last night and theoretically they should have lowered my car but they did not, so now I'm going to cut them. The moog 5658 springs certainly lower the front end and have a little better spring rate to handle that stage motor. All the aftermarket springs like hotchkis, global west, suspension techniques, etc would all work as they lower the front end and are a little stiffer rates.
Any idea how much the Moog 5658 spring will lower the car?
84TX, what is the measurement from the ground to the top of your fender lip with the 5660's?
Original Parts Group Incorp.(Chevelle Parts, El Camino Parts, Monte Carlo Parts, GTO Parts, Cutlass Parts, Skylark Parts, Restoration Parts) has lowering springs for G-body cars. (OPGI.com) Under Monte Carlo you will find springs for both front and back ranging from 1",2" ,and 3".Actually down the road was thinking of dropping the front 3" and the rear 2" they are a direct replacement for stock springs. Of coarse we only have 15"s and can get away with dropping and not rubbing. Think they(OPGI's) go for a buck sixty a pair. Non of this Eibach .5 to 1" drop.
Actually Intrax(either Summit or Jegs carry Intrax springs) make a complete lowering set(front and back) for 2 and a quarter. Drops the car I think 1.5 in front and 1.8 in the rear. Also QA1 makes a conversion coil over called the pro I think that adjusts from 1-3 inches. The bottom of the spring narrows and sits on the shock and the top of the spring widens and rests in the upper a-arm. Spring is shaped like a Tornado!Over 3 bills to do the front with the coil overs.
If you check out opgi when you go under suspension(Monte Carlo) hit see more and a longer list will come up. You will see low profile springs, they have spring for V8's,V6's with or without AC they are 164 a pair. Good luck getting the lowered meaner stance,
